My N/A is being rebuilt...
Started by James H, June 09, 2008, 12:04:32 AM
James H
Sadly the water seal is shot on my fc n/a & is to be rebuilt soon, have already be advise to put a FD flywheel on it whilst it is in bits was wondering if there are any other jobs/parts/mods that can be done to improve the old girl also if i can source them for good £ is it worth getting new injectors on her as they are leaking, thanks!?!
Rebuild time is always a good time to check hoses and the other ancillaries on the engine - plug leads, injectors, water pump, alternator, and so on - although your engine builder should check these for you and advise if any of them need replacement.
James H
Very true & will be hopefully they will let me do a few jobs whilst they are busy on the engine, some places are bit funny bout you working in there workshop for insurance reasons. It\'s going to RE:Worx & from what i have heard most seemd to talk highly of them. I have heard of peolpe closing off ports on the 13b, is this true & what is to be gained from this?
Brett
Out of interest, whats the advantage of the FD flywheel?  Presume the counter weights are the same etc?
Brap Brap Brap Brap
James H
Yes i asked the same waiting to hear back bout it!?!
Quote from: Brett;506494Out of interest, whats the advantage of the FD flywheel? Presume the counter weights are the same etc?
I think it\'s lighter than the FC one.
dthebuk
i always heard the clutch was one of the best things to replace, or at least the pilot bearing
:burnout
James H
Has had a new clutch on only 1000 miles ago, not sure bout the the bearing\'s thou will bere in mind, thanks.
antnicuk
a stock FD flywheel can be fitted to a turbo II but not an EGI, it has the wrong counter weight.  Also, i think the egi clutch is smaller than the TurboII/FD.
James H
