Few questions :)
Started by interloper393, May 19, 2008, 09:49:12 AM
interloper393
Hey peeps just a few idears iv been toying with u after some advice :)
1. Do slam panels make much difference to temps? toying with the idear of a custom one in fiberglass as theres too many bends n curves to try a metal one, plus it`ll tidy the front up a little, just your opinions plz :cheers
And would normal 2 pack paint and clear withstand the engine temps if i painted a few bits? engine bay paints the same as the car and that never has any issues, tiz what im thinking below as im p`d off polishing the things every month lol, so if painted a quick wipe over n its spotless any.. just dont wanna have the paint flaking off with the heat, and powder coating a cost me money :P
from this:
to this:
cheers
John_Hudson
i like bud, also can you drop me an email at asthier@gmail.com i lost your addy and i want to ask ya somethin \';)
Nik da Greek
I painted my intercooler pipes just with a Halfrauds Vintage Red rattle can and they\'re fine a year later, no flaking or bubbling or anything. Ooooh, get you with your photoshops! I\'d leave it polished were it me, the only reason I painted mine is cos I can\'t afford a polished elbow and efini y-pipe, but whatever flicks your switch. Better hope someone don\'t buy it off fleabay whilst your spraying the pipework up!
allstaruk
I\'m planning on going down the custom fiberglass slam pannel route, although my knowlede of fibre glass extents to fixing bumpers.
interloper393
lol its not that hard bud, im always open to helping a hand :P
allstaruk
Cool, shame were at opposite ends of the country, what I need to work out is normally I use many thin layers of fibreglass, is there a way of useing thick glass and getting a load of resin onto it easily, also I\'m always going through brushes as they just glue them selves together.
rx7boy
#6
i like the engine bay looks wicked gonna do mine in red and black
DM-Motorsport.co.uk
rx7boy
I know a rotary engineer who is starting to make slam panels for the FD he uses two seperste sheets of aluminium, dont think they will be expensive as he is rebuilding my car for 1.6k. let me know if you are intersted and I will give you his contact details
DM-Motorsport.co.uk
interloper393
Quote from: allstaruk;500458Cool, shame were at opposite ends of the country, what I need to work out is normally I use many thin layers of fibreglass, is there a way of useing thick glass and getting a load of resin onto it easily, also I\'m always going through brushes as they just glue them selves together.
you just buy thicker mat, i use 1.5 oz mat, and all you do it wet the area first that your fiberglassing then stick the mat down onto that then wet out... for the brushes use acetone, it breaks uo and burns off the resin :D
Ricco_04
I have all my pipes dark to try and mimic a more factory look bay (excuse the picture - from August! :2Confused) :
