sludge on oil filler cap
Started by joes7, May 18, 2008, 08:53:18 PM
joes7
Hi,
your help is needed again ! after about 3,200 miles I have noticed a significant amount of sludge (creamy/greyish in colour) on the filler cap and the tube leading up to it, as if there was a water leak, but cant understand why ? water level seems ok any ideas / anything to worry about ??
cheers
joe
AshRX
Nope nothing to worry about. The cars dont have a breather and therefore the sludge has no where to go
joes7
cheers for the quick reply - how often does this happen and is there anything i can do to stop it ? and will this cause damge ??
AshRX
depends car to car, tend to get it more in cold weather. Other half\'s 8 suffers from it but clears itself after a good run and when the weather is warmer
shaunwil
Yep, the yanks call it lung mustard. Not much you can do with it but leave alone.
Shaun
SiH
SmbFD3S
Quote from: SiH;500100Head Gasket :(;)
LMAO :rollin
\'92 UK RX7 FD
\'86 Honda CRM250R stroker
\'11 BMW 320d ED
batman
head gasket pmsl just wipe it out when you top oil level up
interloper393
catch cans reduce it, never had any on mine with one fitted :)
hairyhoover
Quote from: AshRX;500085Nope nothing to worry about. The cars dont have a breather and therefore the sludge has no where to go
are you sure? i thought there was a breather just off the oil filler neck?
PS were do you plumb the catch tank into?
Martiny
Quote from: hairyhoover;500198are you sure? i thought there was a breather just off the oil filler neck?
Yes but have a look at where the breather goes - to the manifold. (This is to satisfy the emissions numpties because it does not breath to the atmosphere.)
Therefore the moisture does not dry out.
SmbFD3S
Quote from: Martiny;501805Yes but have a look at where the breather goes - to the manifold. (This is to satisfy the emissions numpties because it does not breath to the atmosphere.)
Thats true and remember also that if you are are on boost then the system is positively charged which is why there is a one way valve so it wont be "breathing" at all....
\'92 UK RX7 FD
\'11 BMW 320d ED
