Loosing coolant Help!!
Started by rx7pat, July 16, 2008, 09:46:33 PM
rx7pat
Hi everyone my fc\'s engine went last year, but managed to source a engine in working order. Spent a couple of weekends swapping the engines. Got it all reconnected and started the engine.... well it starts but wont run on idle just cuts out after a couple of seconds. but the main worry is my coolant dissapares rapidly and steam seems to come from around the left side of the engine near the turbo??
Any ideas if i could have got a connection mixed up or something that would cause this?? thanks pat
When you swapped engines did you damage the engine as it went in as there are the water journals around the outside of the engine, plus when you swapped the engines had the new engine had new water seals and stuff?
rx7pat
the engine was rebuilt by dragon so should be good. I was pretty carefull when i put it in so i dont think anything got damaged. what do the water journals look like?
pdtaylor18
The turbo is water cooled so make sure all the unions are tight, it may well have been disturbed during its original owner.
Email: pdtaylor18@hotmail.com
Pete[SIGPIC][/SIGPIC]
rx7pat
ok gonna check it out now thanks
rx7pat
ok anyone got any ideas the engine will start run fine above 3000rpm but if i let off to allow it to go to idle it dies after a few moments??
Perhaps the idle adjustment screw?
TiddlesRX7
Is it still steaming or not? If not then try the idle screw on the BAC valve if it it is still steaming then like above, check all the fittings on the turbo as its water cooled.
rx7pat
i seem to be loosing coolant still but it was only steaming out by the turbo because one of the gaskets was damaged. i tried it again and even if i control the throttle if i let it fall below 2000rpm it sounds really rough and cuts out. which makes me think it is something else? as the car wont even run anywhere near idle. do you think vacum problem? I can post a video later if it helps? thanks
TiddlesRX7
If it does run smooth above 2k rpm then it sounds to me like the engine itself is ok. It could be something like the AFM or VAC leak of some sort. I\'d be a bit worried about loosing water though. That indicates one of the water seals in the engine is leaking. It would explain why its running rough from what i\'ve read about it. Lets hope its one of the easy fix things.
pdtaylor18
I would do a few things and in this order:
Compression check (this will dispel a coolant leak or not)
Air flow meter (check volts and resistance)
Check throttle cable tension
Check and adjust Throttle Positioning Sensor ( Cured my eractic idle)
Check values at the BAC
If you can get some fault codes from ECU? is it standard?
Check all vacuum hoses even if you have to take the UIM off.
Has this engine been run since rebuild?
Tighten all intercooler hoses and any associated hoses.
Check all earth points, there is one under the throttle housing, one goes to the right hand bracket support for the TMIC, one from the gearbox to above the clutch reservoir.
There are several at the front by all the front light connectors etc but these mainly for the front end. The engine ones are very important to ensure a good smooth running engine.
If you can swop the ECU, It has been known to get wet.
rx7pat
ok thanks for all the input guys really appriciate it!! will check all these things out and keep you posted, patch
