Main Menu
Abs
Started by mread4, March 26, 2008, 08:03:46 PM
mread4
Need a abs sensor asap for my FD does anybody know where i can get one?
TonyC
Which one. I\'ve 3 out of the 4 for sale (second hand but ok)
[SIGPIC][/SIGPIC]
mread4
Its the offside front.
TonyC
I\'ll check and get back to you. I know I\'ve only one front one left...
[SIGPIC][/SIGPIC]
TonyC
Doh! The one I don\'t have is the drivers side.
[SIGPIC][/SIGPIC]
mread4
ok nice one, its the last part i need to finish the car. Its had a total rebuild front and rear and its the only part that would not come off without it braking.
m4drx
can i ask how you know when they need replacing?
my car has a mystery fault so abs is non operational and the light is always off (i think the previous owner took the bulb out).
fduk.
mread4
Mine broke in to bits trying to take it out. I know people do take the bulbs to get it through the mot. Does your abs work?
m4drx
nope :(
no obvious signs of what it might be either. its all there but just doesnt work.
fduk.
mread4
Your abs does not work. I hate abs anyway
TonyC
The workshop manual has a bunch of diffrent reasons as to why the ABS is shut down and no light illuminates - all to do with circuit connections between the control unit and ecu. Not much you can do with the sensors except check resistance is as expected. The workshop manual describes an ABS tester which plugs into the ABS ECU system to check for faults.
Not sure what there is to hate about ABS, it\'s not like it fires off all the time or causes you to stop slower or anything.
[SIGPIC][/SIGPIC]
mread4
Think i might just take the bulb out for the mot and just use a anchor to stop.
mread4
On some cars, which have the abs light always on, i have found just taking the sensors out and cleaning them has worked.
m4drx
thanks peeps.
i do want mine working again as in the dry its ok as i run aftermarket pads etc but in the wet it locks under hard braking so i would like it to work.
just dont know what to do about it really. :(
fduk.
mread4
been looking at other threads on the same problem and it seems to come down to the ECU and trying to pull codes from it. Im no good with ecu\'s etc. I use http://www.jimmys-rx7.co.uk/ he has done alot of work for me and it might be worth a phone call.
