Interior Refurb
Started by Timmy, March 08, 2008, 09:08:05 PM
D2BBA
Quote from: Matt_KNoo I think what he\'s asking is that his carbon bonnet\'s gone a little cloudy with age, and would using a similar technique to how you\'ve polished up your carbon bits work there too.
Impressive work with the carbon fabric, what polish do you use?
Corect that man!
Sorry, should have made myself a little clearer!
Chris
p.s. its on my Bro\'s car not mine incase anyone who new the car was confused (more!)
Timmy
Good stuff here i think i may do some c.f parts. Some of it will definatly just be sprayed, im not gonna carbo lay my whole storage bins.
ENVYD
say if you got a hole in a panel (that you need) that your covering with carbon how would you go about that?
interloper393
fiber glass the back of it, then a thin layer of filler and sand smooth :) job done :)
im looking at a few overlays soon so i`ll pop a post up.
A handy trick is to apply a thin layer of resin and wait for it to go tacky, then the cloth will stick to the correct shape and not move around
ENVYD
no no i mean if there is a hole there that you need to keep? i.e. for a switch or your dials? would you just cover it all then cut the hole away!
SmbFD3S
Quote from: ENVYDno no i mean if there is a hole there that you need to keep? i.e. for a switch or your dials? would you just cover it all then cut the hole away!
That would be the easiest way of doing it yeah :D
\'92 UK RX7 FD
\'86 Honda CRM250R stroker
\'11 BMW 320d ED
markj113
use a dremmel to cut out the hole afterwards
ENVYD
Quote from: markj113use a dremmel to cut out the hole afterwards
would you do that after the 5-6 layers of resin or before you put them on? may be asking alot of questions but i have never used carbon before!
markj113
do it after the resin.
