Help fitting harness please
Started by Tim_B, March 08, 2008, 01:03:26 PM
Tim_B
Fitting a harness at the mo, a sabelt 4 point.  UNfortunately I\'m pretty useless at practical stuff :(
Am just looking at the left and right sides of the belt for now (presume rears fit where rear belts are ok).
On the left I\'ve unscrewed a bolt behind the seat rails and screwed in the eyebolt (correct name?) thats on the end of the belt.  Now this may sound daft but how do you tighten these things?? do I need to?
On the right I\'m not sure where to put it, there\'s a big screw that goes all the way under the car (near seatbelt) - can I remove this and put the other eyebolt here? or is it holding stuff in place?
Any other suggestions on fitting welcome :Thumbs-up
Jimjitsu
I think you just undo the 2 bolts at the back that hold the seat rails down then put your eye bolts under them as for the two upper points of the seat belt they are ment to go on a roll cage I think.Maybe the rear strut brace might do the job without a roll cage fitted im not sure you can make a really safe job of it
Tim_B
Have fitted them now.  Was tempted to use seat rails but have them in other places now, seems to work ok.
I put the rear points where the rear belts go - not the best angle, but safer than using the strut brace I think.
Will post some pics in a bit.
Wasn\'t too difficult in the end.  Now I\'m tempted to remove the rear seats too :rolleyes:  not obvious how but I guess there are some bolts somewhere
