Washer jets
Started by the jackel, March 04, 2008, 06:33:52 PM
the jackel
I was wondering if anyone has any idea how to remove the front washer jets from on top of the bonnet. I have had a poke around but can\'t see an easy way of removing them.
For what it\'s worth they are getting spruced up as they have faded somewhat, yes they are red. They are not going to be replaced by LED versions so worry not.
Mike
rx7veilside
they have liitle burrs on them and so need to be edged out from the underside of the bonnet
Ricco_04
Disconnect the pipes and get a pair of pliers up there so you can pinch together the plastic that holds them in place.  leave a small gap bbetwene the pliers and the underside of the bonnet so you can push up and pip the jet out :)
the jackel
thanks guys. Had another fiddle tonight, mix of pliers and screwdriver and managed to get them out quite easily.
Thanks again
