non sequential
Started by tyson23, February 28, 2008, 06:45:28 PM
tyson23
hi
just converted to the non sequential via the poor mans process so can undo
took out for blast and found it was pants the turbo\'s seem to cut in around 4000-4500 is the norm coz when mine was sequential it seems to cut in at lower revs and pull better...me thinks i will be changing back in the morning....
any ideas if this is how it is or is there something wrong
Bulla
Have you told the Apexi what it needs to know ?
Bulla
tyson23
i have a power fc havent done anything to mapping
Martiny
Well, I am not sure what you were trying to achieve by going non-sequential? Mazda made it sequential so that the power would be available at low and high revs.
tyson23
spose i was just curious to see what its like and all the talk about it
dthebuk
is the boost the same high up, but with no boost in the lower revs?
havn\'t really look into this but im quite intrigued
:burnout
Martiny
The boost is the same up high. The benefit of this mod is to eleminate the slight dip in the boost as you pass through 4.5 k. However, you lose a lot of the low down boost.
S3TH
So it\'s like a laggy, very small turbo on stock boost? Oh I see all the benefits now... :rollin
Martiny
Quote from: S3THSo it\'s like a laggy, very small turbo on stock boost? Oh I see all the benefits now... :rollin
thats EXACTLY what it becomes !:Thumbs-up
interloper393
well mine starts boost at 3200rpm.. and its much better i think, its all about what u prefer bud... i  get  better fuel economy too lol
Martiny
The way it improves consumption is because you drive round a low revs most of the time. This conversion has reduced your low revs boost a lot.
I agree its personal choice.
interloper393
i find it alot like the evo 5 i had, boost started around 3200 then kicks you in the nuts.. alot like the non-seq lol
