How to remove rats nest (solenoid pack)?
Started by Jono FD3, March 01, 2008, 08:00:15 PM
Jono FD3
Right then guys, so far I have removed the UIM, throttle body & intake pipes, but what else do I need to take off to remove the solenoid block as I need to test all the solenoids to make sure they are working properly & to change the pipes in there!
If you have got any pics or can let me know how many screws hold down the pack & roughly where they are that would be great!!
This is the stage I am at, at the moment:
Jono
adib
hi jono was going to take mine off ,but gave up think you have to take a few things off to get at all the screws.
Jit
im pretty sure you got to remove the coil pack (2 or 3 10mm headed nuts) to get at the bolts for the nest. Off the top of my heds, there are 3 bolts holding the nest down and then it should only be held by the wiring.
Hayward North
the coil pack has to be remeoved before the rack can come out, its 3X12mm bolts if i rember rightly,takemloads of piccys of every pipemya disconnecte :D
hardest bit is disconectin the fuel lines :S
dun 3 to press :)
Regards
Steve Garbutt
Hayward Rotary North
RobbieRX-7
Hayward North
Regards
Steve Garbutt
Jono FD3
LOL cheers steve! If it all comes out you can have another free beer ;)
Jono
Jono FD3
Right, rats nest has been removed, although not quite how people have said to ;)
Shall I post a how too for people like me who cant get their heads around it??
Jono
