hks twin filters
Started by ratty_ratty, January 08, 2008, 11:46:43 AM
ratty_ratty
hello
i got given a set of hks twin filters for the car when i got the car
but no manual for filling
i cant figur out where the hks pipe with little filter half way down goes
any ides where i can downlod manuals or if any one can post pis would be good:Thumbs-up
thnaks for your time
deanflowers
ive got them saved electronic if you post an email address will send them across, or email me deanflowers2000@yahoo.co.uk
ratty_ratty
FD3SNuttah
that little filter goes on the end of the top pipe coming off the air pump.
ratty_ratty
but theres loads of pipe working goign to the original filter box
its all confusing do i have to get more filters or breathers for them pipes??
FD3SNuttah
i was anwering the query about the hks filter pipe in your original post.  that pipe goes onto the top of the airpump which you can see on the left hand side of the engine - it has a pully with a triangle shaped center bit. its pretty obvious when you look at it.
The other pipes you should be able to fit onto the hks filter metal pipes. UNLESS you dont have them cos i dunno maybe you just have the mushrooms?
leon
What i did:
The Two that connected to the left of the box (looking from the front are the charge releif) i connected to the metal filter pipes. both of these vent so technicaly they could be left hanging and would give you a woosh! but i prefer recirc. (you still get most of that sound!)
The two on the right One of them sucks (litralry) this is the one that goes to the airpump the other one at the back of the engine blows. i put a little filter onto the airpump and if i had the HKS bulb i would have connected it to the rear one. :yes
I woof in your general direction.
ratty_ratty
ok thanks for yout time
