Dash Lights not working
Started by ohms, December 21, 2007, 08:14:35 PM
ohms
Hi Chaps, turned the lights on my FD today and the dash and accessory switches failed to light up, any ideas what could have caused this? Not fun driving at night with no idea how fast you\'re going.:2eek
thanks
Mobilemick
Check ur fuses m8, are the lights at the rear working ?
Mick
Jono FD3
yep, I\'ll second that!! for some reason the japs find it a good idea to put the interior dash lights & rear lights on the same fuse, so when your dash dies so do your rear sidelights!!!
Jono
tinker-27
its a good way of you knowing the rears are not working !!! there is a relay in the front relay box that works the rears and the dash lights, or it could be the reostat in the dash,
bikealarmblair
Quote from: tinker-27its a good way of you knowing the rears are not working !!! there is a relay in the front relay box that works the rears and the dash lights
I\'d never have known that if you hadn\'t said :Laugh
peterwolds
also check those fuses in the footwell
:Typing Pete
ohms
Thanks chaps, will check this out!:)
chopper2k22
If you want me to come up and take a look dude just let me know
Crazy Eddie
Quote from: chopper2k22If you want me to come up and take a look dude just let me know
Ditto :yes :Santa
