windows
Started by deanflowers, November 12, 2007, 03:01:07 PM
deanflowers
My electric windows have stopped working, ive tried replacing the drivers window switch as this seemed quite worn but still no joy :(
I need to check the fuse but iam unsure which one it is, also ive seen mentioned that a relay could be at fault.
If the passenger switch went faulty would this stop all the windows from working?
banned advertiser
No, passenger and drivers switches are independant, so if one brakes the other should be ok.
Could also be the motor
dwarfslapper
try adding a new earth mine worked fine after, take it from the switch to the door  hth
Paul
For sale:Thumbsup! http://www.mazdarotaryclub.com/forums/showthread.php?t=34314
High maintenance,but aren\'t all beautiful girls:InLove
deanflowers
okay will try this.
