Catalytic convert piping
Started by leeroy_25, November 03, 2007, 08:09:55 PM
leeroy_25
Can someone please tell me how many pipes should be coming off it the catalytic cnverter and also should it have an exhaust gas sensor in it? I have so far got one pipe coming down to it from the air pump. I have also noticed that there is something missing towards the back of the CAT on the passenger side? there is a small hole and two threads sticking out? Should  have more pipework or is this for a sensor? If so where will I find the sensor wiring as I haven\'t noticed and plugs under there!
If someone can post a picture it may help a lot.
Thank you
Lee
probedb
Mine had an EGT sensor and a pipe for the air pump....don\'t remember anything else.
leeroy_25
So I am definately missing the EGT sensor! Where does the wiring for it go to?
Does it screw in a round hole or is it held on via a plate and some small nuts? Will try and post a pic of mine today..
Thank you
Lee
Jit
theres a grommit which brings it into the car...its got a plate built into the sensor held on by 2 nuts. can you give ma  bell pls dude as it looks like the unthinkable as happened
