HKS hard pipes in need of polishing...
Started by michaelb, October 26, 2007, 02:59:30 PM
michaelb
Hi All
I have the HKS racing suction induction kit with proper HKS hard pipes.
What do I use to get them clean / polished? where do I get it from? I don’t want to go mad but I would like them to look new and shiny.  They don’t look too bad thou..
Any ideas?
Regards,
Michaelb
Rixio
Il do them for you if you like...drop me a PM :)
michaelb
Chaps
I need to have them polished on Sunday for next week set up so any suggestion tonight would be welcome, I would like to buy the stuff Tomorow is pos
Regards,
Michaelb
Rixio
Theres a polishing kit on ebay for about £40 but it\'d take a few days to get to you...and unless you have a very good drill and dremmel its not worth it...as i said its very time consuming aswell :)
You can get Autsol from local Motor Factors and that is good but doesnt work well on unpolished stuff...
HTH
Rixio :)
cab69er
ali polishing kit from cromwell tools . cheap n cheerfull but does the job all you need is a power drill!!!!!!!!!!
Timmy
you can wet and dry it first than polish compound than autosol. Or if they\'re not too bad just autosol and elbow grease.
Christopher
Are you talking about these pipes?
I used Autosol metal polisher with some cloth. If you dont think its shiny enough after that then use some water and fine sandpaper then use the Autosol and it will "BlInG" :p I only used Autosol and a cloth to get mine like that.
ashc
the amemiya pipes i got were so scratched up i wirebrushed them with an electric drill, then went down the sandpaper from 400grit to 1500grit, then autosol and it was fine. Not mirror finish but a very even satin look.
michaelb
Quote from: ChristopherAre you talking about these pipes?
Thanks for that...Incedentally the pipea I am talking about are the HKS Racing Induction Kit...I must say that one could eat off your pipes they are so clean.  Can I get the autosol from Halfords?  The fine sant paper is also a very good idea, I will get some too...
Regards,
Michaelb
michaelb
Guys, thanks for all the suggestions, I will get autosoll...
Regards,
Michaelb
michaelb
Quote from: ashcthe amemiya pipes i got were so scratched up i wirebrushed them with an electric drill, then went down the sandpaper from 400grit to 1500grit, then autosol and it was fine. Not mirror finish but a very even satin look.
satin look will do me fine
Regards,
Michaelb
