replacement mirror glass
Started by nick english, October 23, 2007, 11:58:30 AM
nick english
does anyone know a place online where i can get custom made replacement glass??
need to remove my glass in carbon effect mirrors as shown but they will break when removed so i can chop them down and rethread them to make them lower as i think they look too stuck up in the air!!
John_Hudson
can\'t you chop it from the other end?
i think the bottom bit looks abit long & the top isnt too bad
nick english
no it has a ball at the bottom so if done that way it would have to be rewelded which i cant do and i have to get to the wiring inside the mirror so figured this would be the easiest way round as one of the glass is allready bust and needs replacing.
barmar
Most Glaziers should be able to cut a mirror for you if you take the broken one in as a template.
Barry
nick english
Quote from: barmarMost Glaziers should be able to cut a mirror for you if you take the broken one in as a template.
Barry
ok cheers m8 i will have 2 give that a go
