mmmmmm quite here isnt it
Started by mpk490p, September 29, 2007, 08:18:41 AM
mpk490p
Quote from: David NockThe write up sounds perfect. Again only a 4 line set but it would be possible to get that rear axle line made up seperately somewhere else.
I would have gone down this route but every time I saw \'4 line set\' I assumed there would be something else wrong with them. Sounds like Mark got the full 5 lines somehow.
it was 5 lines i got but i carn\'t find the link got them from ebay a little while ago now, sure it didnt state 5 though, i brough a seperate clutch line and was going to get another to do the job but when 5 turned up i just thought result!
mpk490p
#46
Just fiquired out where my brake lines came from http://stores.ebay.com/TriNET-Brake-Systems_Mazda_W0QQcolZ4QQdirZ1QQfsubZ10QQftidZ2QQtZkm drop them a line as they dont advertize them
Mark
shaunwil
Never asked how hard the front bushes where to swap over ?? Got them sat here and need to get it done but been a bit lazy with it due to needing it all the time !
Mark, did you swap over the lower ball joint too ??
Shaun
mpk490p
mine were nice and easy didn\'t change the ball joint as i was told you can\'t change them (they come as part of the wish bone although i have seen them advertized on there own
Mark
shaunwil
Dragon auto does sell them on their own, probably a press job too !
Mine looks farely rusty in the front and the bushes look crusty.
Shaun
mpk490p
Quote from: shaunwilDragon auto does sell them on their own, probably a press job too !
Shaun
plenty of WD40 then! mine was part restored when i brought the shell and i think the bushes were done then as they weren\'t to bad when they came out however they were rubber so best to upgrade, sure you can replace the ball joints mine are still good so i didn\'t look any further into it!
Mark
