Could this be my boost problem!!!?????
Started by Jono FD3, October 06, 2007, 04:35:59 PM
Jono FD3
Just started to take the blowers off to get the wastgate ported..... started to pull the small feed pipes off from the blowers & pipe work & look what I found:
Basicaly, all is good & does what it\'s supesed to till it hits 5k ish on the taco.... then the boost just spikes to what ever it wants to..... Max 1.1 bar!!
interloper393
hehe yeah i had similar on my last one bud, i tryed to glue mine but just didnt cut it... just go non-seq :D
Jono FD3
Can\'t be arsed mate.... to much work involved!!!
I\'m bleeding enough now as it is!!!
John_Hudson
Quote from: interloper393just go non-seq :D
Doooo It!!!!
Jono FD3
Is that all it is??? a 1 way check valve!
Think I\'ve got one up the garage!!!!
Jono
m4drx
try that first before going any further i have some if you need anyway mate.
check that as it is a pressurised line and is very important.
if you boost issues continue it may have alot to do with compression im afraid mate.
fduk.
Jono FD3
I\'ll start with the cheap fix first & see how we go from there!!
Jono
