13b + carb + nitrous?
Started by Carolgees, September 08, 2007, 09:23:25 PM
t2rew
Quote from: CarlYeah,.........................cos I am the only one who can take all of the stick for doin it!
LOL
Carl
and hats off too you :Ladys-man
vonrumble
My n/a has gone into garage today to have a straight through exhaust made up for it, as the stock one had more holes than a slice of swiss cheese. Single exit also. Hope it sounds beefy and give me a touch more power. :)
billybobbooth
does anyone know what the holley carb set up by raing beat is like for a rx7 1988? check out www.racingbeat.com its on there uner the 1985-1992 rx7 section its called a holley intake or something ment to work with a non ported 13b? im really intrested but as its carb its putting me off and not sure how it would run on a 1988 rx7 as i have an afm and this wouldnt use the afm!!??
billybobbooth
ok but how hard would this be to set up? i.e. im guessing i need a new ecu to ger rid of the afm ect this i would prefere as its tbs not car and carbs tend to need regular set ups as i found on my dads old car! ill give you a call tomorrow as im off!
gillard28
TBH i got bored with reading all the posts in this but if you wann do nitrous on a rotary you have 2 options.
1. go to the usa or aus and get help
2. get the right gear and go for it.
There is not 1 person on here that can help you no matter how much they rate themselves
scott
BlitzBoy
Or Puerta Rico they seem to be kings with Rotaries and Nitrous, from the little I have read you need things like a modified E-Shaft,ECU,very strong Ignition System so the spark does not blow out as the inlet charge will be veryyy cold, but yes no one in this country has developed Nitrous correctly for the Rotary as yet
Rotorstock winner 08,09
New Project
"el fénix" RX2 by Mark & Mark
