Induction Kit installation - Help!
Started by Bunggle, September 21, 2007, 01:01:05 PM
Bunggle
Probably been asked a thousand times, but I can\'t find the answer.
I bought an induction kit on ebay like so: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&rd=1&item=140158050743&ssPageName=STRK:MEWN:IT&ih=004#ebayphotohosting
Problem is, there are no instructions with it and I have no idea what to do with the smaller hoses that go into the airbox. Can someone give me some help please?
Kym
Rixio
The kit doesnt look that smart but...Post a pic up of your engine bay and the new kit and il try and guide you through it :)
Draco
ok do you still have your airpump fitted? as i have the same piping but not using those airfilters. I am using HKS filter instead.
As i have removied my airpump I did not need the smaller hoese so they were blanked off. all except one with i put a crankcase air breather on it. they are rater small airfilters ;). If you need pics i can post. just pm me
Bunggle
Thanks guys :)
Yes, I still have the air pump fitted, and I think the other hoses also go into the turbos? I tried to get some breather filters from motorworld last night, but they only had 12mm ones which are too small I think.
Draco, could you post a pic please? What size breathers did you use?
(Rixio, I can\'t post a pic of my engine bay, as it takes 2 people to open the bonnet at the moment - release cable is knackered. It\'s a standard FD air box though)
Bobbit
This looks a similar set up to mine, i\'m using K&N filter i got from Rotaryart, there should be about 4 smaller diameter pipes that lead into/out of the old air filter, the 2 that come from the standard blow off valves/ reflief valves can be vented to the air as they do not \'suck\' in air they vent it. The two remaining go as mentioned into the air pump and need a 1 inch flange. I used this link and found it very helpful: Clicky. I\'ll try and get some pics up for ya bud. HTH
:Laugh LOL
Bunggle
Just to let you know, I got a couple of breathers from Halfords at the weekend and successfully fitted the kit. Thanks for all your help guys :) now I just have to work out what is causing there to be oil coming out of one of the turbo intake hoses...
