Rx7 Wheel figures
Started by neil_jdmr, September 09, 2007, 11:21:53 PM
neil_jdmr
Wondering if the pcd is 5x114.3 for all fd3s models also what the offset should i fancy a new set of wheels.
Jit
yes it is 5x114.3
id be looing at offfsets from 38-50 for an fd
neil_jdmr
38-50 offset seems a rather big range, what is the factory wheel offset?
CharlieP
factory is between 38 and 40 i think
Jit
factory is 50 on the 17s. its just like the hondas you are used to iirc..i thin factory is 50 but you cacn run up to 35
probedb
Factory is also 50 on the 16x8s as well.
I\'m running 18x9.5 with a 38 offset and they\'re right at the edge of the arches, same for the front with 18x8.5 with a 32 offset.
neil_jdmr
Excellent work thanks again fella\'s
probedb
I think actually mine are 35 rear and 32 front....will have to double check this evening :)
Morrmat
Quote from: probedbI think actually mine are 35 rear and 32 front....will have to double check this evening :)
have you got any pictures? I\'m looking at upgrading my wheels and want them to stick right under the arch lip
Morrmat
Quote from: Alex1986there u go mate, he\'s posted a couple here:
http://www.mazdarotaryclub.com/forums/showthread.php?t=42555
thanks mate :)
