Tunning Tips while engine is out..
Started by leeroy_25, September 02, 2007, 01:44:06 PM
leeroy_25
Ok guy\'s perfect opportunity..
I am starting a project with a blank canvas.. Engine and box is out.. what tunning tips have you got for me.. Not sure If I wil be breaking open the engine yet.. So at the mo just external tips and auxilary parts. what can I take off or change to make it go a bit better? Anything I need to be careful of? The car is basically a bog standard 1993 Type-R. Any tips gratefully received.
Lee
RobbieRX-7
Just make it more reliable. Replace all the rubber hoses in the rats nest and eliminate the air control valve, double throttle and pcv valve. Are you keeping the stock twins or going single?
leeroy_25
OK. First What and whre is the ra\'s nest.. heard about it lots but not sur what it is. sounds nasty! does it need to stay?
Next when you say illiminate these few valves.. do you mean take them off and bypass them? let me know what is where! I take it there are no side effects to doing this.. I will check the turbo\'s are good but plan to stay on stock turbo\'s for now.. How much boost can these take or is it not wise upping the boost on a rotary?
thank you
Lee
interloper393
if you have an apexi then id say remove the air pump, acv, double throttle and 2ndry butterflys and port the plenum as much as poss :) and fit a decat pipe, if the engines in bits then a streetport 2 ..
underneath the plenum is where the rats nest is bud, it looks dawnting but its not to bad if you do 1 pipe at a time lol.. i enjoyed doing mine..
leeroy_25
Here is a laugh!! What do you mean by the plenum? I am guessing the inlet part at the top of the engine but not entirely sure which bit you mean.. thank you. Can I do some of this even if I am not yet running an apexi?
Lee
interloper393
yeah large metal chunk sitting at the top middle of the engine bay lol..
U cn do it all but dont go over 3k rpm until its been remaped else you`ll go boom...
RobbieRX-7
Doing the rats nest is really easy with the engine out, but i wouldn\'t do it without these diagrams. If you remove the double throttle, air control valve and pcv valve, you may as well use the simplified diagram with less pipes and less solenoids.
Also take a look at these http://www.mazdarotaryclub.com/forums/showthread.php?t=42027&highlight=diagram
leeroy_25
Oh My God!!
All the coloured pipes!
Christ that is a lot of pipe work! guess I will be needing a large roll of silicone hosing then?!
Lee
Adie Moore
what and where is the pcv valve.
cheers adie
RobbieRX-7
You wont need much silicone hose.3-4 meters should be enough with some spare. This is a link to the full diagram. http://www.turborx7.com/images/Technical/vacuum_hose_diagram2.jpg
 I just followed this and took out what i didn\'t want. I have no experience of doing the simplified version with less hoses though. Follow this guide for more help http://www.robrobinette.com/hoses.htm
The PCV valve stands for purge control valve. It just vents the fumes from the fuel tank into the intake manifold. I removed mine with no ill effects.
Adie Moore
leeroy_25
Yes indeed.. Thank you very  much! Do you know what size piping I need off the top of your head then I can order some up ready!
Lee
