bonnet release cable
Started by anthony, September 24, 2006, 06:54:07 PM
anthony
wheres the best to get a replacement? will a mazda dealership stock these still?
anyone got any tricks of releasing the bonnet now the cable seems to be problematic.
cjr
pair off pliers and brut force, check out the banners
A small turbo
anthony
thanks just ordered it from rotary art, brute force it is then :)
mike01
Quote from: anthonywheres the best to get a replacement? will a mazda dealership stock these still?
Hey Anthony,
How did you get on with your bonnet release problem.  I\'ve got the same problem but I\'m not getting anywhere with the brute force and pliers method:mad: . Can you (or anyone for that matter) offer any advice?
Cheers,
Mike
rx7veilside
have someone push down on the bonnet to relive pressure before pulling cable from inside the car
mike01
Cheers for the help, but the cable had dropped out its catch and it wouldn\'t release.
Found some advice posted by Spartacus which did the trick.
Seemingly there\'s no problem a coat hanger and a pair of pliers can\'t fix:Thumbs-up
