How do I remove my front reflectors?
Started by jsrx7, August 12, 2007, 03:13:27 PM
jsrx7
Hi,
Can anyone tell me how I go about removing the orange reflectors on the front bumper?? I found this post which says you need to remove the inner arches first to access the screw for the reflectors. Is that right and how do you remove the inner arches??
Thanks!
probedb
Yep, just unscrew the arch liner near the reflector enough so you can get your hand in with a screwdriver, then unscrew the reflector on the inside :)
