What width Rubber
Started by Teighto, August 31, 2007, 04:14:15 PM
Teighto
Any suggestions as to what Tyres width i should run on...
17x8 Front
17x9 Rear
i wouldnt mind stretching it a bit ;) ;)
any help appreciated !!
Jit
Id stick to the good ol formula... 235/35 up front and 255/40 out back...
J.j.
235/45/17 F, 255/40/17 R.
These are the tyre size on OEM 17" wheels.
Having said that, can someone tell me that why aren\'t they same width front n back like the 16" wheel cars?
FDs are 50/50 front and rear so why aren\'t we running same width tyres? Always thought only cars with rear bias weight distributions run wider tyres on the back, eg: elises, 430s, 911 ........
Think RE-A Touge car runs 255s are 265s all round.
Jit
reason i run the wider rears is because i dont want to change the steering weight by running wider ones up front but I do want a bit more rear end grip.
aeseaton
I run 235/45/17 on front, 265/40/17 on rear. Gives a nice sharp turn in and loads of back end grip. Also helps protect the rims a bit aswell. What rubber are you considering? Im currently on Falken FK452, would reccomend them to anyone, im very pleased with road and track handling. Hope that helps.
\'96 RX7 Bathurst R - 452 bhp on BNR twin turbos.
\'99 Impreza RB5 - 320 bhp daily driver.
\'04 CBR 600RR - Nuts warmer
\'96 Frontera TD - Motorway tug and tow slag.
//www.timgraymotorsport.co.uk
Engine rebuilds, Race car prep, Car modification, Track day rental
