High idle
Started by Tim_B, October 20, 2007, 06:57:15 PM
Tim_B
My Fd seems to be idling higher than it used to.  Always used to idle at 700rpm on the dot (in normal up to temp conditions).  Now it seems to be 1100.  I know its not stupidly high but can\'t work out why its increased :xconfused
Also I\'m getting a bit more backfiring.  Anyone got any ideas?
Stock FD btw, cheers
Carl
Sounds like you may have got a vacuum leak.
This can be a small pipe that has come off or split or maybe the inlet manifold gasket has broken through,is the engine rebuilt? I ask cos if it has been then it will have had a metal inlet manifold gasket put on,or indeed if the car is post 95 it will too.
Regards
Carl
Tim_B
Cheers. Its had a rebuild and is a 95.  So I guess probably a vacuum leak - easy fix?
