Adjustable FPR
Started by Morrmat, July 19, 2007, 05:55:33 PM
Morrmat
Which is the best one to go for? Are all FPR\'s adjustable?
Matt
Morrmat
gonzoninja
Nope some fuel pressure regulators are fixed.
Something like and Aeromotive FPR is a rising rate regulator
Ricco_04
There is a Sard FPR in the for sale section ATM :)
I use one of them on mine with the guage so I could set up the fuel pressure.
Morrmat
so to make the SARD one adjustable all i need to do is buy the attatchment off of ebay?
John_Hudson
The attachment will allow you to plug it into the 2ndary rail then feed a line from that, i believe its the thread on the top of the fpr that adjusts the pressure
Ricco_04
The only bit you can adjust is what pressure you want it to run at (from idle IIRC)  You adjust the two nuts on the top for this - you wont know if you have it right unless you have a guage attached which will tell you what the pressure is.
Hope that makes some sence! :)
