Burning a hole in my wallet
Started by Rocho, May 07, 2007, 11:09:01 PM
RedRummy
Quote from: RochoThanks Kevin. Thats exactly what I wanted to know.
Diverting back to the ecu, I\'ve found this...
http://www.fc-datalogit.co.nz/datalogit.html
Bacially does exactly what I want. Has anyone used this before? I\'ve just got one concern, having the PC always connected to the ecu whilst driving then mix in windows crashing or some other fu, is there any risk in this situation? I will of course only be using it for monitoring but still I think you may see where I\'m comming from?
Yep, that\'s the baby.
That\'s what most tuners use to tuner the Rex\'s... trouble is, its expensive.
What computer set up have you got?
You can monitor the ECU\'s settings in real time (up to eight at anyone time as it has eight data channels)
You can also write back any changes you wish to make, for tuning purposes... but as i say, it costs a fair bit.
"Life moves pretty fast....
Ferris Beuller, 1986.
Rocho
I\'ve now got in and working fine (this is an old post) I haven\'t use it for tuning, she is just running on the base map and will be tuned by WGT in two weeks. After that the next upgrade will be a lambada sensor (hopefully one that can also talk to the computer) so that I can start tweaking her myself.
I\'ve got a mini-dell pc hooked up to an lcd touch screen.
gsb876
Quote from: RochoHow do?
Are there any meets going on round here that you know of?
I occasionally meet up with the FTO boys, want to join us sometime?
Just the bubble inn meet which was today but i didn\'t go as woke up late !!!
details: //www.davewilkinsgtr.co.uk
If you go to past meetings you can see my rx on the pics, the matt black one with huge rear wing.
Let me know if you wanna convoy down for Rotorstock buddy, sunday 12th August, am gonna put a thread up in the convoy section shortly.
Kev - did you not sell your FD then matey ??
Gurj :D
