Dial lights not working
Started by John_Hudson, July 19, 2007, 07:28:50 PM
John_Hudson
Hey im having a problem with my illuminated dial lights, when i put my side or full lights on the dials wont illuminate, ive traced the fuse to the internal fuse box but when i change it and try the lights again i can hear the fuse pop and there goes another one.  Im guessing its a grounding fault somewhere but im not even sure where to start : (
any idea\'s?
cheers
John
John_Hudson
FD3SNuttah
im in the same boat after respraying my dash! :( im gonna have to take it apart and then see what i forgot to plug back in?!
has anything else stopped working on yours? does the dial lights share the same fuse with anything else?
John_Hudson
Nothing else has stopped working, just the dial lights,  ive been looking through the wiring diagram if you have the PDF its on page Z 80 :)
Im actually out on the car now running over everything that i did before it went poop
RedRummy
"Life moves pretty fast....
Ferris Beuller, 1986.
John_Hudson
LOL, sorted it now :p
only things i had done were a boost controller and changed my shifter bush so just went over the controller wires made sure they were all tidy, ensured the earth was good as well and cleared up the wires under center console.
Seems to be working now although i cant really tell as the sun is blistering here!
