Boost controller
Started by rossgal, July 03, 2007, 12:18:13 PM
rossgal
Hi, I have bought a universal type electronic boost controller for my 1993 RX. Can someone help in as to where the control solenoid should be fitted? And where the pipe for the guage should go? Many thanks for any help.
nikp
The solenoid can go anywhere you like. Try and keep it away from too much heat, and dirt ingress. And as close to the area where it\'s being spliced into is probably best.
rossgal
Hi, I`m actually looking for a bit more detail as to what pipes, etc to fit this into. Cheers.
Hayward North
If im understanding you correctly then your wanting toknow where to tap the hose onto.
If this is the case then you can connect it to the nipple on the left (looking from the front of the car) of the UIM.
If there is already a hose on there then just put a T piece on there.
Regards
Steve Garbutt
Hayward Rotary North
Hayward North
Quote from: strange_days_ukhttp://robrobinette.com/search.htm?boost%20controller
Some really usfull info on there, add it to your favs.
Regards
Steve Garbutt
strange_days_uk
Quote from: steve garbuttSome really usfull info on there, add it to your favs.
Is a top website that..
