Loosing Oil........
Started by pete sparrow, April 15, 2007, 12:32:26 PM
Jono FD3
You will never get a 100 % seal on anything unless you are realy lucky!! but aslong as there isn\'t too much it shouldn\'t be a problem..... just keep an eye on your lvels to make shure!!
Jono
m4drx
when i first got it it had a leak from two banjo bolts at the front and i sorted that without an issue after that it literally drank hardly any oil compression is 7.8 all round so that is good too.
this time i was expecting the same issue as before as i didnt change the washers but it seemed to be the return pipe, i took the bolts off but seeing as i couldnt budge the bugger i just tightented it up best i could an cleaned the area so i can check later but i also decided to check inside the housing as i said but the dribble of oil when i put my finger in ( all else flywheel etc bone dry) it was a little oily to one side - is this normal as i have a clutch issue also?
clutch issue i have had for a while but it does not slip under boost at all and can launch hard if need be but seems to have no real bite to it, i suspected the master or slave cylinder after this so i had it bled which improved things slightly but left it from there, could this be the problem or just a cooincidence?
fduk.
m4drx
this is a pic of the hole in the housing im talking about which was weeping anyone know what this is?
fduk.
