Passenger side mirror
Started by silverdevill, June 18, 2007, 09:50:17 PM
silverdevill
Thought i\'d ask this question first, before i start something i cant finish. My passenger side mirror has worked its way loose and is annoying the **** out of me, how do i get to the back of it to tighten it again and whats involved. cheers.:Hammer
Get hold of the whole mirror head assembly, twist it 90 degrees and then you will see the retaining bolts that are loose on the base where it joins onto the door,
BTW you don\'t need to take the door card off to tighten the bolts/scews
Hope this helps
silverdevill
thanks clive, just been out and had a look but have\'nt got a screwdriver big enough. i\'ll take her to work tomorrow and do it there.  i\'ve just been looking at the craft square carbon ones and i must say i\'m very tempted to impulse buy a set!:spank
