Power steering relocation kit
Started by marky, June 10, 2007, 06:15:43 PM
marky
Hi all
Does anyone know who does a power steering relocation kit for the gen 3 rx7.
Seems to be in the way if i fit a front mount intyercooler and stand up rad
Regards
Mark
marky
I take it there isn\'t one then!
Or people have not had any trouble fitting a front mount intercooler and stand uo rad. To me the power steering pipes are in the way for the intercooler and radiator to be fitted in front of eachother.
Any ideas?
Smifta
I believe most people *bend* the pipes as needed to get them fitted.
310 atw. Stock twins. Mazdaspeed GT-Concept.
interloper393
you cn try fitting an electric one, think the saxo pump fits the rex ok bud, saves a fair bit of room.. there was a post on a guy doing it on here if you do a search should pop up :)
marky
Thanks for the replies, think i\'ll try and bend them a bit, i would like to try and get the intercooler and rad as close as possible. At the moment there\'s about an 8" gap between them
Regards
Mark
shaunwil
Don\'t bury it under anything though, it needs to cool. You can kill the pump if the fluid overheats. I\'ve got a little oil cooler rad cable tied to the back of the intercooler. Just do a search for when i upgraded my FMIC.
Shaun
marky
Hi Shaunwil
What did you do just cut the steering pipes fit the cooler and jubilee clip some pipes to it? Or something a little more technical?
Regards
Mark
shaunwil
link to original thread :
http://www.mazdarotaryclub.com/forums/showthread.php?t=22582&highlight=cooler
Basically I cut off the metal lines and installed rubber lines to a mini oil cooler that is sat behind the intercooler.
Shaun
marky
Thanks Shaun
Thats been a great help mate!
All i need to do now is get a cooler move my rad and intercooler and fit them all close together!
Regards
Mark
