High knock on commander after rebuild
Started by RobbieRX-7, June 08, 2007, 03:46:14 PM
RobbieRX-7
After rebuilding my engine, i took it for a nice country drive.I\'ve noticed that the knock levels had peeked to 58 on the commander. I obviously kept off bost and under 3000rpm. The car has been standing for 2 months. It did have V power in the tank but this may have lost some of the octane levels by now. Would rebuiiding the engine cause the timing to alter in any way? What sort of level is a \'safe\' level? and what would cause it?
Kash_
the knock sensor can ocassionally become faulty and give false readings. The main thing is if the mapping has been done right then you should have nothing to worry about. The readings on mine are ridiculous... sometimes 25 on 0.8 bar then it might jump to 170 just taking off at the lights in first gear with no boost... :2Confused
antnicuk
ignore the knock when your off boost, it makes no difference you wont det while off boost, wait till you run it in and get it mapped.  I got rid of the knock sensor on all of my engines,  i found it makes no difference to whats actually happening.  I think you will find the tuners dont take much notice either if the tuning is good,
Ricco_04
Don\'t most people chuck on the standard ECU for running in as they wont hit positive boost? Or does it not make any difference?
D1 WTF
Quote from: Ricco_04Don\'t most people chuck on the standard ECU for running in as they wont hit positive boost? Or does it not make any difference?
not that i have heard of, although if you are running single then you wont be able to anyway
Ricco_04
Quote from: D1 WTFnot that i have heard of, although if you are running single then you wont be able to anyway
Ta very much! :Thumbs-up
