A couple of questions after my engine reinstall
Started by probedb, June 05, 2007, 01:10:22 PM
probedb
Hope someone can help :)
1. The EGT sensor that connects to the cat, can I just join the wires up or not, someone mentioned I needed a 1200 ohm resistor in there? If so can I just use a normal electronics one or does it need to be rated for more current/power?
2. Until it\'s started and is running ok the standard ECU is staying in, will the car start in limp mode (i.e. caused with a broken EGT sensor?).
3. Will the car start without the connectors attached to the gearbox?
I think that\'s it :)
Cheers!!
paul.
