Help! Coolant problems
Started by dhracer, May 06, 2007, 02:43:03 PM
Lum
Quote from: davehgi also think its a leaky/blocked pipe etc, its definately not the engine. worst case it may be a weapy rad, thats quite a common thing on old FD\'s. check for a damp patch or see if there is steam coming off it when its up to temp.
Right you\'ve fixed that!
Now sort out where my water leak is! :chat
davehg
its your rad nanananananana
dhracer
Lum, I\'ve now got a pressure tester if you need one to find the problem :rollin
Lum
That would be great mate! Would i be able to use it this weekend? Think i\'m loseing coolant around the turbo somewhere! and it\'s evaporating before i\'ve seen it!
dhracer
Yeah no worries, this weekend is fine :)
