What grade of grease do I need ???
Started by Red and Single, April 22, 2007, 11:56:38 AM
Red and Single
I\'m replacing my diff and the grease which goes in the driveshaft sockets  needs renewing as it is dirty.
It does not feel like normal grease, can anyone shed any light as to what grade I should be looking for ??
Thanks in advance guys...
Dave Hughes
kev-yorks
Its probably a lithium grade grease if it smells. If you put lithium grease in anyway its about as high as spec as you can get anyway.
Kevin
Regards Kevin
Yep that what we use.
Just make sure its spotless clean before you load it up with grease and make sure the Boot is not damaged/Cracked then use some good quality clips (make sure you don\'t have grease on the Boot-Shafts mating surface, it just seals better and less chance of moving about)
Red and Single
Thanks guys for the help...am doing this job today :D
Dave Hughes
