brake disc removal/caliper piston stuck
Started by mosguido, April 02, 2007, 04:08:57 PM
grinder
err nope !!
im sure they are screwed in - so you might need a stud extractor - or you can sometimes use 2 nuts - lock them tight against each other and then loosen the one nearest the hub
this should lock up even tighter against the 2nd nut and draw the stud out
failing that - bit nut on the end and weld it on :D
The tightest man on earth
:Giggle
mosguido
hmm cheers for the info, never easy dammit. why can\'t i get a problem like having a dirty air filter or something for once.. haha
ah well by the time i\'ve done all the stuff to the car it should be tip top :D
grinder
again - welcome to the world of FC\'s - nothing is simple - at all :D
:Giggle
mosguido
just to ask yet another question...brakes are still squeaking when pressed (most of the time), i\'m pretty sure its just cos theres no shims fitted yet (should be arriving in the next few days) and wanted to double check its probably cos they arent fitted (yet).....i think so as the brakes stop nice and solidly, they just like to squeak :D
also..is there a step by step anywhere for removing and refitting the wheel stud just so i dont mess it up when i do it! cheers
Guy
mikeysrx7
Hi Ya
I agree about sticking rear Calipers, took the dealer 4 hours to free one of mine then it stuck again 600 miles later and now failed MOT, replacement Caliper £110 +VAT & Fitting!!
FC Turbo II Cabrio & 13B Cosmo!! - Must be mad!
