How do you remove the plenum??
Started by Jim_rx7, April 06, 2007, 11:49:06 PM
Jim_rx7
Want to get access to vac hoses etc to replace them.
thanks in advance.
gmogle
Easy job mate, just take your time !!!!
http://www.clubrx.org/default.asp?id=5&ACT=5&content=63&mnu=5
Also I will stress that when you see about removing the pipes from the solenoids you need to heat the ends and cut them off, DO NOT CUT THEM WHEN THEY ARE COLD OR YANK THEM OUT !!! They will snap the ends off the solenoids and you will need new ones !!!
Jim_rx7
Cheers mate, I\'ll have a read! :)
Crazy Eddie
I have just removed plenum and used this guide:
http://www.mazdarotaryclub.com/forums/showthread.php?t=35508&highlight=double+throttle
HTH careful with those check valves and solenoids. I broke 2 check valves just by rushing and at £15 each I wish I hadn\'t :D
Jim_rx7
This might sound stupid, but how can you damage the check valves? What should I be carefull of?
Fats
When lifting the plenum off there are about 3 or 4 vac pipes just under the throttle body which are attached to the solenoids, there is 2 check valves there aswell from what I remember. just lift it and remove the vac pipes they are on the same side as the throttle linkage..
Jim_rx7
How long should it take to remove the plenum and replace the vac lines?
allstaruk
Plenum about an hour,
Changing all the vac lines properly atleast a day.
A
