not sparking
Started by tezz12345, March 31, 2007, 07:46:16 PM
tezz12345
haveing a problem thought i flooded it so before i took plugs out i brought all new plugs and de flooded it changed plugs old ones were all carbened,
could not get it started and pulled one out and there is no ark on plug when i turn it over, so no spark!!!!
checked egi relay and all fine. need to know where earth is to block so i can check that, and gotta check other things like coil pack but if amyone can help with any other ideas please say!!
also is it worth unpluging ecu and plugging in again ? is there a reset button on standard ecu?
 any help would be welcome thanks
LRP
make sure the amplifier hasant come unplugged its by the abs block on the wing it also has a earth??
complete wankel :god
