Complete newbie question about compression..
Started by Matt_K, April 02, 2007, 11:15:29 AM
Matt_K
I\'m almost embarrassed to ask, haha.
http://www.youtube.com/watch?v=SFfIhXMnaNc
Is that a what a proper rotary compression test should look like? I\'ve never seen one before, only people\'s results written down :o Also i presume thats in bar, and does that look like a good result for a 50,000KM motor?
stylus350
As far as I know those are very good figures. Never seen one done either.
Oedipus Rex
looks like an awesome result for a 50km motor. mine was 8.2 8.4 8.4 --- 8.2 8.2 8.3 fresh after a rebuild.
John Yorke
So he only tested one housing????????????? numbers look to good for a 50k motor
Matt_K
So what would artifically make the numbers look better than they are/should be?
And he tested both, That was off the leading rotor. I have the other set of results somewhere at work, similar figures. (Cant remember off the top of my head)
khyber pass
that\'s a solid set of compression readings (as long as the other set is as good!?)
Mine sits at 6.8s all round...and according to Pip, it was good for a few 10\'s or 1000\'s yet...
Apparently, more of a concern if you\'ve got uneven compression..
