PFC install problem
Started by Mb3d, March 30, 2007, 09:19:44 PM
Mb3d
Help.....trying to fit my new pfc & controller, changed out the ecu etc all very easy, turn on ignition and no flashing lights on dash, turn the key and try to fire it up for the idle self learning and it splutters and coughs and pops up and down but wont run. I tried a couple of times but, no more until I get advice, I\'m up in scotland so no chance of popping round to wgt etc etc.
What is the issue regarding the idle screw adjustment when fitting the PFC
It is the right PFC for the car BUT i recently changed the engine over from another 94 import, and I forgot to check the injectors, is there a way to id them without actually removing them.
My car is import 94 model and the apexi is the Z004 91-95 with the commander, I have hks panel filter in the stock airbox, standard downpipe and 3" decat exhaust super magna something from japan, stock intercooler, new battery, good leads and new plugs (all 9\'s) the car run fine on stock ecu.
Anyone know whats needs to be corrected?
shaunwil
First thing to check is the voltage of all the sensors on the car. Sounds like the TPS may not be in spec. I think its in the misc menu under sensors.
Do a search on PFC and TPS and there should be a few threads.
Shaun
Mb3d
