Why are the doors noisey ?
Started by Jim_rx7, March 28, 2007, 08:21:32 PM
Jim_rx7
Curious as to why the doors on the FD sound like that of a transit van when you shut them! ... lol
I\'ve heard they can be hard to shut on these cars, but why?
chrisBoid
Air pressure.  For some reason the FD is not very good at venting the pressure quick enough from closing a door.
I open my door when my girlfriend has to close the boot as this means she doesn\'t try and slam it with all her force, prompting a telling off from me.
Also, I\'ve heard that the door aligning slips over time and needs re-adjusting which doesn\'t help.
Jim_rx7
The whole air pressure thing.... I take it that\'s why the sunroof moves when I slam my door shut?
Just doesn\'t sound good getting out a flash car when the door sounds like a transit van!! lol
Ricco_04
Quote from: Jim_rx7The whole air pressure thing.... I take it that\'s why the sunroof moves when I slam my door shut?
Yep thats why!
Quote from: chrisBoidI open my door when my girlfriend has to close the boot as this means she doesn\'t try and slam it with all her force, prompting a telling off from me.
Lol  have had a moan at that before myself! :rollin
Told a mate you have to give the door a firm shut else it will not close properly.  So gives it a good slam but seems to try and shut it further than it will go - result = broken door handle! :rolleyes:
Open the window a tad eh :yes
ro284
I think to save weight Mazda did not fit any sound deadening inside, mine sounds tinny! orrible,  i hope to stick some in mine one day!
Bob
D1 WTF
thats where my alarm is good, can open the windows and shut the doors.  then lock the car with key fob and the windows go up....;) ;) ;)
Rixio
#6
Get some foam wadding and some sound deadening on the inner door...sounds clunky with a nice thump rather than a clang now :)
http://www.mazdarotaryclub.com/forums/showthread.php?t=24779&highlight=sound+deadening
Try this, Take the Door pad off if you look at the Back of the door skin you\'ll see a bar thats 3" wide that runs the lenth of the door, these are suposed to be bonded to the Door skin but tend to come loose over time and ratle when you shut the door, what you want to do is pump a bit of Sikaflex behind the bar (between the bar and the Door skin so your bonding the Bar to the door again) this will make the door sound alot Quiter.
Unfortunatly there is little you can do about the sunroof moving when you slam the door, as its already been said thats air pressure and nothing to be worried about.
Bobfish
^ what he said.
I packed out my door bar, now sounds nice and solid when you shut it.
