Knackered door locks.
Started by ramirez, March 17, 2007, 04:18:09 PM
ramirez
My RX7\'s driver\'s door keyhole lock is knackered and wont open by key. Any idea what sort of cost is involved in fixing something like that?
I was wondering if just getting a keyfob for remote central locking would cost a similar amount?
Any ideas?
Brett
I would advise relying on remote opening just incase the battery goes dead. As a short term measure I would suggest you switch the barrel from the passegner door to the drivers.
Also (thanks Moonwrap) Mazda can produce you a lock barrel to match your existing Keys.  This is done by using the number etched onto your key, there may be a short wait for the barrel to be made though, its expensive either.  Moonwrap says they did it even for her Cabriolet which is JDM, so it should be pretty simple :)
 Changing/fitting the barrel is not hard either, just remove the door card and everything will become clear :D
 :wave
Brap Brap Brap Brap
ramirez
Cheers Brett I\'ll get onto that :)
Brett
Thats meant to say I WOULDNT not I would by the way.... stoopid brain isnt fast enough these days...
Brap Brap Brap Brap
strange_days_uk
Quote from: BrettThats meant to say I WOULDNT not I would by the way.... stoopid brain isnt fast enough these days...
wouldn\'t not I would advise ?
wouldn\'t not advise ??
:Giggle :Hammer
Brett
Brap Brap Brap Brap
Makes a change that the locks won\'t open, T2\'s have this trick of not needing keys to open the door locks, i could open mine with a screw driver or even the wrong key :(
TiddlesRX7
just been to the mazda dealership. lock barrel and key for £77. Not too bad really I don\'t think
