Boost probs???
Started by Jim_rx7, March 17, 2007, 05:56:01 PM
Jim_rx7
Read the test when you\'re supposed to be in 3rd gear, then boot it etc.
Boost goes to just past 0.6bar, then drops to 0.5bar, then stays at 0.5. Is it not supposed to go back up again??
Anyone any ideas as to what could be the prob?
thanks
Jono FD3
Do you get a kick up the bum at about 4500 rpm???
This is when the secon turbo comes on line & you should notice a big surge of power, if you don\'t then the second turbo isn\'t kicking in & that could be down to a load of things!!!
Jono
Jim_rx7
no noticable kick up the bum.
Any ideas what could be the problem??
Where do I start?
Jono FD3
Could be a duff pipe in the rats nest, nackerd solonoid........
Jim_rx7
lmao... so what\'s the possibility of me diagnosing it?!
Mmmm... think I\'ll have to get the car to a rx7 specialist at some point.
Jim_rx7
Is there certain pipes that are used with the turbo side of things that I can look at replacing to see if this resolves the issue?
Jono FD3
Yep...... all of them!!!
The rats nest lives under the UIM & the pipes cook there, they get brittle & crack, so you mightjust have a broken pipe, but it could also be a solonoid gone!!!
Jono
Jim_rx7
Actually, I changed my mind. It seems ok as far as I can tell now?!?
Will get my garage at some point to replace the vac pipes etc, etc. Are they easy to get to without any major hassle?
PS : what is the UIM ?
strange_days_uk
Upper Inlet Manifold, also known as plenum.
Big silverish probably corroded intake, elbow connects to it !
