Where do?
Started by Andyp, January 11, 2004, 05:53:17 PM
Andyp
Where do the large wire holes in the side wings go down to?
I tried tracing them through the other side, took all the dash off and it went from the gearbox all the way up past the air con controls etc which is where I lost it as I didn\'t fancy pulling all that crap to bits.. so I think they had that in the centre console..
I can see the wires for where they fitted a Water temp gauge going down the drivers side wing but I don\'t know where they come out.
threading the wires from the engine bay to the cockpit is the last thing I have to do now :)
much thanks
Buy my car foo! :D
maximtaylor
There is a hole there, but it\'s covered in carpet and other bits n pieces.
Easiest way to get there is to look under the the back of the wheel arch under the inner wing, you will find some holes. Put large non sharp object through hole(s) (tiny torch is ideal for this pokeing through business) and then try to find the other end from inside the footwell, quite high up.
Regards
Max
