Stereo blanking plate
Started by GaseJo, February 28, 2007, 02:48:51 PM
GaseJo
Hi all just a quickie,
After i removed factory stereo i needed a solution for the hole left over from fitting a single din stereo in. I intended on fitting 3 gauges in there but decided against it. So i was lucky enough to find someone who makes these
At some stage i will be fitting a blue neon light behind but as it is i think it is a good & tidy solution to the problem.
Cheers Garith.
