bit excited...
Started by Archbish, February 18, 2007, 01:48:02 PM
travellinbob
Just got a pm yesterday I think from tony and he said that it was Tim who did it but it was ages agi. I too was asking about rack stuff.
antnicuk
Tim did my conversion but it was 10 years ago and i think he would never do it again as it was quite griefy.
I nearly did the FC/FB conversion again and i was going to just bolt the whole TII subframe to the FB chassis rails. Its only 4 bolts.  That way you get the 13b engine mounts in the right place, decent power steering, excellent brakes and more choice on shocks.
Thats what we did on the FD Tripple, it was a days work maximum.  Just need to make 4 good mounting points to bolt subframe to and measure the points for the top of the shocks.  If you use an FD subframe, it doesnt matter about the top of the shocks as the FD camber is set by the top wishbone but you would need make a point on the inner wing to mount the top wishbone.
Edited to say:  I have an FC subframe with steering rack ready to collect if someone wants one.
antnicuk
Michael,   empty your mailbox i cant reply,
here is what i tried to reply
 Cheers for the tech support:Thumbsup!
 Just thinking that if i was to put the rack in front of the struts on the moggy then surely when I turn left the car would go right as I would have moved the steering arms to the front of the struts???
 ![/QUOTE]
its funny you should mention that, i remember Tim having that issue, it was funny at the time :D
I would have to see the car to remember what we did, but thinking about it, the FC rack works the right way in front of the engine, you are just fitting it in the same place on the FB/Moggy.  I think the FC track ends attach infront of the wheels and when we swapped the FB ones it worked.  But i am kinda guessing :3Confused
travellinbob
i have a rack from a turbo II spare in the workshop so I will get it out tomorrow and lay it down in front of the moggy to have a see.
 cheers, michael.
 o and mailbox is completely empty now!
Don Pamponi
Edited to say:  I have an FC subframe with steering rack ready to collect if someone wants one.[/QUOTE]
I might be interested in the subframe if I can find some one willing to fit it for me (I\'ll ask Tim).
I have a 12AT, would that work with an FC sub frame?
Where abouts do you live antnicuk?  I\'m in Tunbridge Wells.
Now with added boost!  :burnout
Don Pamponi
Just spoken to Tim, he\'s up for it.  I beleive you are seeing him Monday?  If we can sort it out in time you could bring it down with you perhaps.
(If you get this in time)
Give me a ring & let me know what you want for it.
01892 523900
Don Pamponi (aka Tim from T-wells)
