Rad Bottle?
Started by aeseaton, February 18, 2007, 09:23:48 PM
aeseaton
Ive just replaced my radiator bottle on my gen 3 as i had a front end smash. After changing the radiator this weekend i noticed that the fluid was spilling from a tiny hole in the top of the bottle after i had been running the engine at operating temp. This never happened before and im just wondering if anyone can shed some light. Ive checked all the connections and pipes and they are fine, but this doesnt seem normal.
\'96 RX7 Bathurst R - 452 bhp on BNR twin turbos.
\'99 Impreza RB5 - 320 bhp daily driver.
\'04 CBR 600RR - Nuts warmer
\'96 Frontera TD - Motorway tug and tow slag.
//www.timgraymotorsport.co.uk
Engine rebuilds, Race car prep, Car modification, Track day rental
RobbieRX-7
Which radiator bottle do you mean? Is it the expansion tank in the drivers side wing or the ast to the right of the alternator?
aeseaton
Bottle in the drivers side wing with the filler neck just behind pop up light.
RedRummy
it is supposed to leak from the area where the filler neck joins the bottle... or rather, its not actually fixed in there, its just resting in it. Not sure if there should be a hole there though... i thought it was just the filler neck sitting in the hole in the top of the tank.
I\'m assuming you know that at as you approach operating temp the coolant water expands and the expansion tank (the one in the drivers side wing) is used to hold the extra water till the system cools down again.... as it cools, some water is sucked back into the systyem to maintain the right level.
(grannys sucking eggs etc)  :)
"Life moves pretty fast....
Ferris Beuller, 1986.
aeseaton
Ill have another look but im sure its got a tiny hole on top of bottle next to feed pipe from rad. Maybe its just an overflow? I might have put a lil too much fluid in to start with so maybe just equalised the amount.
RedRummy
yeah, it is supposed to overflow if over filled
(I know that from bitter experience :)
aeseaton
well hopefully its sorted itself out now. engine is runnin smooth so fingers crossed.
