no sidelights or dash lights
Started by troy619, February 17, 2007, 07:14:31 PM
troy619
i posted bout not having any dash lights jono said check my rear side lights i did and they aint working nor r my front side lights.we\'ve had all t lights out out 2day and checked everything they r all earthed ok but not getting any feed 2 them fuses all ok can any 1 help please
pete sparrow
Check the wiring film on the back of the dash/instrument pod/ dail housing/dail binical. Some of the filaments might have burnt out or broken,causing your lights to fail. If all intact give all the plug/connecters a clean and make sure they\'re all secure. The dash pulls straight towards you and needs a good pull to clear it.Don\'t pull too hard as the wiring is short. Best to remove the steering wheel as well.:)
troy619
thanks pete they all do work cuz when we run a live wire straight from t bat 2 front side lights everything worked front&rear side lights and all dash lights were on
Crazy Eddie
And you have definately tried a new fuse in the drivers footwell location for this?
Does sound like fuse as the same one went on mine and exact same things affected???
Do you have the manual and fuse layout?
Keep updated if not I\'ll be thinking of other things it could be.:confused:
troy619
yeah we thought it was a fuse but changed it 4 new 1 then put multi meter on 2 t new fuse and red ok its very strange i have even spoke 2 ross at dragon a couple of times and hes a bit stumpped i have pics of fuse layouts but no manual thanx 4 t help
Crazy Eddie
Well then it sounds like there is a problem within that circuit. If you put a bulb instead of the fuse in there does the bulb light up or is there not a circuit?
If bulb does not light up could be a bad connection on fuse box itself so try reading resistance between that and go from there.
Strange one really do you want a manual on CD might help?
or have a look here too for more information:
http://www.rx7city.com/93manual.htm
Sorry I can\'t be more help hopefully someone on here may have come accross it before.
troy619
thank u crazy eddie a manual on cd would b very help full cuz then i could test 2 c if its t switch on t stalk
